Transmission locked in Reverse
GerryAllen
Before any of you die-hards rag on me about previous threads, have tried to search info.
Putting new rear end in car, got it ready for a test drive and transmission locked in Reverse. Have taken tower out and in again and still cant get it ti shift, any suggestions would help.
Gerry Birch Bay Wa
Hopefully you did not accidently drop a bolt down in the transmission while you had the tower off. They will hide back by the reverse idler gear, then when you shift into reverse they will jam up and do some damage.
Tom Endy.
You said you put a new rear end in the car then the trouble with being stuck in reverse. Was it a rebuilt rear? Did you rebuild it with a new ring and pinion? The ring gear can be installed on the wrong side of the pinion causing only reverse!
Just a thought.
Mollydog
Just a thought.
Mollydog
Not quite. The car would move forward with the trans in reverse.
If the ring gear is installed on the wrong side you would have 3 speeds in reverse and 1 speed forward
I did this when I was 16. When we discovered what we did, I wanted to fix it before any of our friends came by, but my buddy insisted on driving it around the block in reverse. He did and we fixed it real fast. Never got caught by our friends.
Gerry Birch Bay Wa
Loosen off all the U joint housing bolts and see what happens
Thank you all, got it unlocked. Removed the tower, rocked the car back and forth while gently nudging on the aft gear and Walla it was free.
What a relief, thanks for your suggestions. New to Model A's, this web site and fellow club members really help us newbies with our problems.
Gerry
