51merc
trying to stop this leak that caused the latest damage to the 3 speed OD/Transmission in my '51 Merc.
replaced the tailhousing seal, not leaking there. it's leaking where countershaft exits flush with the transmission housing, visable from underneath the OD adapter plate between the OD and the transmission housing. is there anything i can add to the transmission lubrication to help stop this leak? i'm currently using 85-95W gear oil. or is there another oil i may have to switch to, to get something that i can add to it. BarsLeak products say they'll work with any transmission oils, but is this 85-95W gear oil considered transmission oil?
don't want it to leak dry again, the transmission leaks, the OD spills into it, and runs dry, and the OD seizes up. how do i know this? don't ask.....
