1959 Edsel Ranger, 292 V8, 2 speed aluminum case Mile-O-Matic - restored.
When the car sits for a while (couple months) I get a fairly heavy leak from the speedometer cable. When I reassembled the car I replaced the o-ring on the cable and it is dry at the case so I don't believe the o-ring is leaking, it's farther down the cable.
Is the speedometer cable housing suppose to seal internally? Would replacing the cable solve the problem?
Or is the problem that the transmission fluid is draining back into the pan (dip stick reads high after it sits for a few days) and it gets too high in the tail?
During restore I did pull the transmission a part to clean it, adjusted the bands put new front and rear seals in and replaced the servo seals and cover seals. I had it open and draining without the valve body in it for about a week in several different positions and I drained the torque convertor.
The manual says capacity is 10 qts. I put about 1 qt in the torque convertor, reinstalled and put in about 8 more (1 shy of capacity). It reads just a tad low on the stick when warm.
