Brian T
I am rebuilding a 3 speed transmission for my AA truck, I have salvaged a good gear set from 1 of three transmissions that I found , 2 of the housings are the later type (29) the end play in the cluster gear was around 021”, with some scoring in the housing.
My question is should this scoring be fixed, or will a shim JB welded to the thrust face work?, there doesn’t seem to be any hard and fast rules as to how much play is to much, factory recommends 003” to 005”.
The other housing is a (28) with the thrust washers, I did not check the end play upon dismantling, I do have new washers coming for it along with the (MNPL) as per Tom Endy, your input would be very helpful.
Brian T.
Brian T.
