Yes, and yes! DD
they go in a 32 also, but its a tight fit. some times some grinding is needed, and you have to put the front bearing on while the shaft is in the case if i remember correctly.
There can be a problem with a clutch over 9" fitting the case.
i'm told that my case is a 32. i thought it was a 35. will 35 rear mount fit on my 32 case?
A picture of the case will help. To put the late gears in you need a case with the 2 1/2" dia rear thrust surface. The '32-'35 case ("18" & early "48")had a small rear thrust surface while the later "48" cases had a large rear thrust surface.i'm told that my case is a 32. i thought it was a 35. will 35 rear mount fit on my 32 case?
