Mac VP
Our lessons from an oil industry engineer......up to GL4 is good, although the GL1 has zero additives and generally only recommended for straight cut gearsets (no synchros). So what you can find these days is the plain GL1 and GL4......both ok on yellow metals. If you choose a GL5 oil, check with the refiner to confirm that it is ok with yellow metal. Some are and some aren't. This is why we only stock the GL4.
