Brother A
I'm about to change my transmission fluid. I haven't done that since I bought the car last year. It may not need to be changed but it leaks past the threads of the drain plug. That makes me suspicious that what's in there is due for a change or the wrong viscosity.
I was reading repro of the Ford "Instruction Manual" for the Model A and it suggested rinsing the transmission with kerosene after draining the fluid. What do you guys think about that? Is it something that was necessary with the fluids of that time or is it still good practice?
Also, I was thinking about using teflon tape on the drain plug just for some insurance. For some reason I recall reading that that may not be a good idea. I couldn't find that thread when I searched. Do any of you recall that?
Thanks for your help.
Steve
Steve
