Transmission Extension Tube Removal
Tikker
Well my frustration level is at about a 9.9.
I have another thread asking for input as to how to remove the seal at the tail shaft/spline end of the transmission.
I replaced my u joints and thought it only made sense to replace the rear seal, wished I'd left that alone.
Tried all of the things suggested and even got a slide hammer I thought would have the appropriate attachment. The seal is still there and buggered enough to make it ineffective.
I'm looking at removing the extension tube (suggested by the guy I had install the u joints).
Can I simply remove the speedo cable, the four bolts fastening the extension tube to the ****** and pull it straight back and off?
My motors manual says to rotate 1/4 turn CCW and remove, but that has to do with removing the the countershaft.
I know this has to happen, I'm not going to get this seal out laying on my back, it is far more substantial than the replacement seal.:mad:
Tikker,
I just recently removed the rear seal on my `51 F1 but I had the transmission out of my truck. I am not sure if your `52 is the same as my truck. Removing the rear mount bolts was a bear with my new dual exhaust. I did not want to risk damaging my new exhaust as it touched the frame as I jacked up the engine to clear rear mount bolts that are in upside down. By working and prying was able get the two bolts out. After I had the transmission on an engine stand I cut the mechanic’s wire and removed the rear mount. I put it in a vise and used a claw hammer to remove the seal. It popped right out. Too, this gives you the ability to press the new seal in, lessening the possibility of damaging it. Don’t ask me how I know. I bought Mac Van Pelt's book on transmissions and it is invaluable when working with transmissions. Too, you are working with an outstanding individual that is just a phone call away.
I hope this helps..
Tikker,
I hope this helps..
You don't say whether you removed the extension tube.
I'm hoping to do that instead of removing the whole transmission.
If this is an overdrive trans, I strongly recommend that you have a shop do this.....someone familiar with OD trannies. Even if it's a regular 3 speed trans, you have to partially disassemble the trans to get the rear housing off. This means pulling the trans out of the car. This is where you basically get to learn how to rebuild a trans. Or, you get more creative and persistant to get the old rear seal out. Take a deep breath...
Go to your friendly Ford dealer and ask to borrow their tailshaft seal removing tool. They have various sizes of these special tools. They are hollow expanders with a "catch lip". The tool gets compressed to slide over the tailshaft but through the seal. Upon relaxing tension the tool expands and the lip will grab the seal. A bolt in the center of the tool is tightened against the end of the tailshaft and the seal can be pulled out of the housing.
Both of the last two replies are telling me what I have suspected.
The tool is also one I have seen on ebay, but I couldn't get dimensional information to verify it would work on my particular transmission.
It isn't an OD trans. but my motors manual does describe a more involved dis assembly than I had hoped for for just wanting to change the seal.
Back to ebay.
Maybe there's a Barner near you who could help or an Early V8 Club member. Seems like that seal should have been out of there days ago.
Paul in CT
Tikker,
Please ignore my response. My truck transmission is different than yours. I just viewed a picture of the two transmissions together. My apologies...
I would go to the local too rental shop and get a proper seal removal tool. They all have them. I have been know to be too lazy to go to the tool rental shop and ended up using a cold chisel to weaken the seal enough that it fell out. I don't recommend this as you can damage the housing, making the housing difficult to seal up again.
The seal sits tightly in a pocket, which leaves precious little of the back side of the seal to grasp...unless it was a common aftermarket seal. The original seal has a full metal shell (front-back-sides) and is the toughest of them to remove. They come easily enough if the tail housing is removed, but that is obviously the stall point for you on this job.
Finally found someone that knows exactly what I'm up against.
Been trying to make all understand, the existing seal is entirely more substantial than todays replacement seal.
I'm thinking my only move is to pull the transmission and take it to a ****** shop and have the seal changed out, probably do the rear bushing at the same time. I appreciate everyones input, I've tried all the suggestions given here.
I'm in Yakima Wa. I have the Ford tool that JWL mentioned. I worked at a Ford dealer years ago and then ran my own transmission shop for many years. I've taken out hundreds of these seals and bushings and never had to pull the extension housing. Many of them before I had the factory tool.
PM me and I'll give you my phone number if you want.
Bill
ford tool that JWL
Thanks to bbrocksr, I've removed the bushing and seal.
He was gracious enough to loan me the exact tool required and it made it effortless!
I appreciate everyone's input to my quest, I knew this was the place to go for answers to my questions.
glad you got it done, so you wouldn't go a 10 on that meter....glad someone was close with the correct tool to borrow, too....congrats.....Mike
