Good morning Guys,
I'm assembling my balanced and rebushed drum cluster and want to be sure of proper clearance between each drum or the total for the assembled three drums.
I assume the clearance is determined by how far you press the end gear onto it's shaft going into it's I.D. I've been told that endplay should be approx. .018" for the total package. May have your advice on this subject? Thanks a bunch...
