Re: Transmission Band Riveting
Drive the split rivet into the fabric of the lining. The split ends go ACROSS the lining, not in line with the band. That keeps any brass rivet wear on the face of the drum to a minimum.
Instructions come with most linings, but if not, the easy way is to use a pine 2x4, rounded top edge is better, to allow the curve of the band to fall away, then drive the rivet into the hole of the band, into the fabric, and the rivet tangs will go into the wood and split over partially. Then spread them with a tool, seat with ball pein hammer to flush down in the fabric.
