Transmission and Differential Oil Capacity
mantta
I want to change the oil in my transmission and differential and I can not find the capacity of them anywhere. Can anyone give me a hand with this? I need to know how much oil to order.
Thanks!
Them plugs on the rear axle seem to be 5/16ths. I guess a 3/8" drive might work. What do you guys use?
Did you mean 7/16"? As I recall the 3/8 is a loose fit, but will work if someone didn't tighten the plug too much. I have a multiplug wrench with the correct size, and the end of the Model A adjustable wrench should have a square that fits the plug. If you use this wrench you can't over tighten the plug.:)
Typo error, I meant 7/16". Thanks all, I think I will cut an end on an old 1/2" socket extension.
A ratchet wrench fits mine I always forget which size so usually bring a 1/2" and 3/8". No need to cut anything just use as is
