J Franklin
You won't go broke if you buy some known good gear oil and use the unknown mystery stuff to oil your tools.
I don't find it hard to find 140 or 250. Been using them for decades.
I find 90 and the synthetics too light, at least for me.
Patrick,
I just changed my differential oil with Bratton’s 600W because that was what I had on hand, but I’ll probably be looking for similar modern oil for my next differential oil change.
Where do you find what you use?
Brattons 600W is 140 gear lube, from the website
This is a 140 SAE industrial gear lube. This product is the accepted oil for the old 600W oil. Transmission: 1 1/2 pint; Rear end: 1 1/2 pint; 7 Tooth steering box: 7 3/4 oz.; 2 Tooth steer. box: 4 1/2 oz. QUART BOTTLE.
I've not noticed this before. I wonder if this is something the Brattons has started recently. It does say this/their oil is thinner than the original 600W. But 140 works just fine. Its what we have used in old transmitters since I was a kid. [ before everyone switched to 90.]
I asked " how can I test"
