Transmision input shaft
pinball73
got a question! what is the most wear tolerance you can get buy with on the input shaft where it goes in to the pilot bearing? the tip end of the input shaft has some wear, not bad but you can see & feel it when you try the bearing on it. I have had worse on later model cars, but they had brass bushings instead of bearings. I am in the transmission & now would be the time to replace it if it needs to be, don't want a problem of jumping out of 3 rd gear. don't really want to spend the money but I don't want too take it out again.
hewe! I have heard of that being done! where do you get the peace that you put back on the end after you have the shaft turned?
Jim's Automotive Service in Southern California re-sleeves input shafts. 714-546-2969
Tom Endy
Tom, do you know if the sleeve needs to be case hardened? Is mild steel acceptable? Does bushing or bearing play into that?
Your opinion?
