Tom Wesenberg
Did anyone mention removing the brake crosshaft for clearance on the rear of the ******? You might sneak it past, but it's so much easier with it out of the way.
Here is what I do for adding height to jack stands when needed.
Cut a 2"x10" and a 2"x4" 12 3/4"s long.
Cut a piece of 3/4" plywood 12 3/4" square.
Using 2 1/2"" screws attach the 2"x4" and 2"x10" to the plywood.
Put another matching piece of 3/4" plywood over the 2"x4" and 2"x10" making a "sandwich".
Add another set of 2x's (off set from the first two so the joints don't line up) and one more sheet of plywood. Make sure that you have a plywood "cap" on the top and bottom of the stack!
This way you end up with plywood on the bottom, 2x's, plywood, 2x's and plywood on the top.
You will need to nip off a bit of the screw tips that will extend out of the 2x's on the first layer. After that the length of the screws will not be a problem.
Set your jack stand on this. Very stable and will not split like logs, rail road ties etc...
You can make several sets and stack two or even three stacks together for added height.
