I have a model B engine and Trans in my model A, just finished putting the new engine and trans in fired it up and took it for a drive, it was hard to get it in second gear, so I pulled it apart to find out why and could find nothing, no play in the shafts no worn gears or syncros, the ball bearings and shafts for the shifter are all new as are the shift forks.
The transmission in a crate with the engine when I got the car and after checking everything it checked out to be as new as one could get Yet I am still having it pop out of second. I put it in second gear and pulled the shifter housing off and looks like its not fully engaging into second.
Is there a way to lengthen the throw to make it go up into second all the way?
