Gentlemen,
Looking for guidance in sealing the shafts of the pedals going through the Hogs head. While taking the H/H apart for cleanig I found thin "O" rings sandwhiched between the cam adaptors and the H/H case.
The cross section of each, measured approximately .059" and the I.D. .541". While assembling with new "O"rings, I discovered those rings are too thin and did not remain clamped in the counter bore of the cams. They bulged out not sealing at all. Did the factory originally install "O" rings? It appears to be perfect application for a ring, so has anyone successfully rebuilt using rings? Would a larger section ring be the answer and does the counter bore (chamfer) in the cams need to be inlarged? Your suggestions, please.
I sure would appreciated it and I know my garage floor would appreciate it.
Thanks...
Thanks...
