sometimes when people rebuild the transmission they put the wrong bearing in there. in the trans there is two short needle bearings and one long needle bearing, and some people the two short ones should go in the cluster gear and the one long one should go in the input shaft. it will jam in there, the cluster gear takes one long and one short bearing and the input shaft takes one short needle bearing.
