Thanks for your reply Mac . My reason for asking is I have just received a detent spring and ball kit from a local supplier here in NZ which according to the label came from a well known supplier in the US . It had 3/8 balls and as you would know they are loose in the bore where they fit , and unless you use stronger springs they allow the shaft to move back and forth , instead of holding it tight . In my opinion , totally wrong .
