All the needed safety there! NiceIn my trailer now - picked up in
the Boston area - dropping off
in Peoria, Illinois …
This beautiful 1956 F100 Custom
On this truck - 6 point tie down
with Mac’s axle straps and
nylon ratcheting cable straps.
Two on the rear axle straight
back from the axle - one on
each frame rear corner crossed
to the other trailer side - one on
each wide slot front wheel straight
This eliminates vehicle shift.
5K wide drum synthetic line
winch line held taught as
a safety line.
Every vehicle is different.
When you put a chain or strap around the rear axle housing, make sure you don't put the chain or strap where the brake line tubing is, as you don't want to crush it.
