fastroadster
I have a 29 CCPU what length of trailer would be adequate for this. Any ideas. I have a chance to pickup a 15X8. Thanks
The only concern withh a 14-16 ft trailer is the strap angles are very steep. It pulls down on with more force but less fore and aft pull. You also want 10 percent of the GVWR on the tongue. Example 1800 lbs trailer + 2000 lbs car= 380 lbs tongue weight for proper handling. If trailer is too short then you can easily exceed. Also no room for winch, tool box etc. I have a 19 ft and it is perfect. It is aluminum with ramps. I would have prefered a tilt bed but the ramps are very light and easy to deploy. Most states require brakes 3000# GVW+ lbs
I have a 20’ aluminum tilt trailer with a tool box and a winch. I use a ShurLine tongue weight scale and have movable wheel stops to make sure each car is properly balanced as to tongue weight. Brakes on both axles with a good controller is a must. This is my third trailer and knowing what I know now, it would have been my first purchase.
