eagle
The trouble is, it will be a TON of work and when it is done it will be worth less than if you had just repaired the original. So many of the modern "improvements" are that way. If you stay within the era, such as installing a 32 V8 or such in an A, it doesn't negatively affect the buyers as much, but stick a pinto engine in there and you've just turned off 75% of your buyers. My experience anyway, your mileage may vary!
