Torque
fortyman
Can someone tell me what the torque should be for a 1940 ford flathead flywheel to crank and pressure plate to flywheel.
the specs for 49-51 Ford Flathead.. flywheel bolts 75-85 (ft. lbs.)
clutch pressure plate bolts 17-20 (ft lbs.)
I think 40 Ford should be the same, others will know
