It looks much the same as the end plate of the roller bearing ---I don't have one to measure in hand but to me it looks like they just used the same dies as the bearing plate, the holes match up---
I have found that sometimes you need 2 thrust washers to get the speedo gear to be centered in the opening.As long as both washers have the lube holes in them,it will be OK.
