I know this has been posted, but is the late '32-'34 banjo casting axle centerline to torque tube flange dimension the same as the '35-'48 banjo casting? Or is it the same as the early '32? I've got CRS.
Is the early 32/Model A dimension different as well from the 33-34?
The '35-'48 dimension is approximately a 1/2" greater than all '32-'34.
Greetings
As a follow up, would using the (late 32 torque/drive shaft dimensions) with the late banjo, result in the rear wheels being moved rearward to the center of wheel well?
JMO, It seems the rear wheels in the stock position, usually appear to end up slightly forward of center wheel well.
Jack
Greetings
Jack
