phartman
The toploader in my '34 is starting to act up. A little background....
The rear and ****** are open drive, out of a '48. The banjo rear has an upgraded axle and gear kit from Hot Rod Works. It also has the third "arm" from them that runs roughly parallel to the driveshaft to keep everything straight under the truck.
Somewhile back, the bracket holding the third arm to the crossmember broke, allowing the axle to twist under load, and to not always run straight and aligned. The truck let me know that the arm mount had broken when I hit a pothole. One of the rear shocks collapsed, the axle twisted, and it was immediately obvious that something was very wrong in the suspension. Luckily, it all occurred at low speed, and I actually made it home ok.
Got everything aligned and re-attached.
However, since then, the transmission has in high gear at 30-45 mph displayed a noise like there are marbles in the case. At first I thought it was wind noise, but it has gotten progressively louder. When it first started to occur, after a while it would go away as the transmission heated to operating temperature. Sometimes I would not hear it at all.
I changed the fluid, topped off the case, and again, the noise settled down.
But with the cold weather, the noise is back. Only in high gear, only at that range (or a little faster).
Bad bearing in the transmission? The binding up of the rear end alignment put a strain on the universal joints and prematurely wore them? Normal sounds for an old transmission?
Dunno.
Maybe you guys can give me some pointers before I go pulling the car down.
Thanks.
Dunno.
Thanks.
