top/molding sealer?
Lee Mitch
The next step on the ground-up restoration of my '30 Briggs fordor is the top. I understand that a sealer of some sort is recommended between the top material and the body, and then again between the top material and the molding. Does anyone have a recommendation on what kind of sealer that should be? Thanks so much.
3M makes a glass/weather strip sealer, it's black and you can get the gun to apply it with, it looks like a pump oil can with a long tube so you squirt it into any cracks or openings. Stuff works great!!! little expensive but it's worth it!!!
I used 3M 5200 (small tube) around edge of material and over tack heads, it is flat black and takes 7 days to cure but remains plyable, and Ive used it to seal windshield rubber on my 64 pv544
