Top iron bracket dimensions -'28-'29 o.c.p.
bobscogin
Can someone give me the dimensions of the '28-'29 top iron bracket as per the attached photo. Need the width, thickness, overall height from top edge to top quarter panel surface, size of hole, and distance from top of quarter panel to centerline of hole. Greatly appreciated! Thanks to Russ40 for the use of the photo.
Bob
I can measure my Roadster if you'd like - pretty sure they are the same. Brookville sells them for about $15 a pair - hardly worth making them if that's what you're doing.
