H. L. Chauvin
A. Correction: Per reply #17, timing gear is turning half as fast as the crank gear. Thanks!
B. Per reply #18, why discuss ignition timing on a subject heading of: top dead center, Model B?
Humble opinion:
1. On Model A forums, "TDC" is mentioned "often" often as well as added on timing cover timing devices used to locate "TDC", & as well as differences in ignition timing with A & B timing covers with recommended 19 degrees BTDC timing for Model B's.
2. It may be mentioned on Model A forums to set the engine's crankshaft "TDC" vee mark at 9-1/2 degrees "BTDC" on a timing device as opposed to setting it on the often mentioned 19 degrees BTDC when using a Model B distributor; however, I never could locate mentioning this 9-1/2 degree BTDC setting when using timing devices and/or timing lights.
3. So often we see a Model A forum connecting rod shim discussion for example with a message heading of Bull frogs in my tail pipe -- so if one is looking for shim discussions he overlooks the bull frog heading.
4. I figured if someone is researching "TDC" & B timing, this "TDC" Model B heading may be read.
5. But in addition, the real reason for posting same is the never or seldom mentioned timing set at 9-1/2 degrees BTDC setting as opposed to trying a 19 degrees BTDC setting which could prevent one from stripping starter bolts or worse, while trying to hand crank, possibly breaking an arm because of too far advanced timing.
6. If this discussion violated forum police rules under this heading, I apologize for thinking of the safety of fellow forum guys.
7. At least the guys in reply #17 & #18 appreciated this effort at 2:00 a.m. this morning. Thanks Rex A Lot & Patrick L.
Humble opinion:
