Tools & odd parts FS
Mark W.
Stockton Springs
Maine
Price
See List
Lots of tools for sale - pictures can be found at this site:
http://www.mtfca.com/discus/messages/3487/579552.html?1445102345
5Z157 wrench is $20.00
3Z647 wrench is $20.00
3Z601 wrenches are $20.00 each (4 available)
5Z156 (one poorly marked – other two unmarked) square main bearing bolt wrenches are $20.00 each
Early “lobster-claw” script pliers $40.00
Other script pliers are $25.00 each and I may have a few others to choose from
KD valve tool marked "Special" is $20
KD valve tool marked "Ford Type" is $25
KD valve tool marked "Ford A & B" is $25
Accessory switch cover “Yale” – as is $15.00
Good used 1915-1918 headlamp switch is sold
The similar toggle is $15.00 (not Ford but would fit a hole)
T Ford spark plug, or open-end wrenches $5.00 each – Many to choose from
T & A Ford Monkey Wrenches $10.00 each - Many to choose from
T Ford hubcap Wrenches $8.00 each - Many to choose from
Car tire irons - early or late Model T style $15.00 each or $25.00 per pair
Ton-Truck tire irons (the flat spoons on the heavy bar stock are TT's) are $25 each (the hammered one is $15) The best 2 were sold.
The Model A spark plug wrench (non-script which is correct for 29 & up) is $8.00
Model A or T Monkey wrenches are $10.00 each
The smaller wrenches are $5.00 each
The short Model A brake tool is $25.00
The longer offset Model A brake tool is $30.00
One Model A screwdriver has a “B” stamped blade and a zinger on the wood handle from a missed hammer blow – would clean up OK – it is $30.00
The other Model A screwdriver has had some file work to the blade, but looks OK for display – it is also $30.00
The Model AA & BB tire iron (long iron w/square hole) is $15.00 – note the chipped spoon end
The short later 1930’s iron is $20.00 - has an odd spoon
The long later 30’s iron is $25.00 - also has an odd spoon
The Model A car tire irons at bottom (flattened & ground spoons) are $15.00 each or $25.00 for the two
The windshield is from a mid 1920’s closed car and includes the sliders & pivots. It has a good piano hinge – moving but tight and the one remaining section of glass could be removed for saving on shipping or sent as a pattern - $125.00
All prices are PLUS actual shipping from zip 04981 Maine. In many cases the small priority flat rate box will get most any of this stuff delivered in the states, and if you are interested in a package deal with any other tools I'd listed I can combine shipping there as well.
Please call 207-323-8994 with questions - leave a message and I will return it (I don't answer at work) - Or you can take your chances by replying here, using a PM thru this site, or e-mail thru the site, but calling is best... I will do my best to answer people in the order of their calls.
