I’ll be the devil’s advocate, why? It takes less than 2 minutes to remove the distributor, and in fact, if you do not want your distributor to rust and lock into the head it is a good idea to remove it just for fun occasionally.[/QUOTe
but to remove the dist you need to remove the armored cable hold down and that defeats the purpose when torquing or retorquing the head
I used an open end claw foot on last one I torqued and did not slip
You will not get a true reading using a crows foot.
Bob
