3 30-9 Well-known member Nov 17, 2020 #1 Hi Gents Will I ruin a 18 volt saws all if I mate it with a 20 volt battery?
K koates Well-known member Nov 17, 2020 #2 It might help if you could explain exactly what you are trying to do. But the short answer is NO and it MIGHT be OK. Need to know make of saw and charger and specifications and also specs of battery. Regards, Kevin.
KiWinUS Well-known member Nov 17, 2020 #3 Desalt now has an adapter for 18 bolt tools that allows you to use a 20volt battery. So as for as their tools you should be good to go.
WABOOM Senior Member Nov 17, 2020 #4 I believe all the big names that say "20 Volt" are actually 18v and they are advertised as "20 Volt Max"
51 MERC-CT Well-known member Nov 17, 2020 #5 Probably similar to running a 6 volt starter or heater motor on 12 volts, just runs faster.
