bchrismer
Hey Fellas,
Long time since I have visited the Ford Barn, but I have a quick question regarding my latest '40 Ford project.
My "beater" panel truck has the '40 Flathead motor from my '40 stake truck. Because the stock radiator was in really bad shape, and trying to throw this thing together on a tight budget, I bought an aluminum radiator that came with a 16lb cap.
Due to the gearing, I can drive the truck at highway speeds turning around 2500RPM, but if I drive more than 100 miles, it pushes at least a gallon of coolant out of the radiator.
I haven't seen any steam in the exhaust nor any milky oil in the engine, but I have seen some coolant droplets on the top end of the dipstick and the driver side head seems to have some "mositure" around it more than it used to when I ran it in the stake truck with a stock radiator and 4lb cap.
Back in 2014, we did have that head off to fix a broken valve guide, so I am wondering if the 16lb pressure cap is creating too much pressure for the head gasket?
This morning, I bought a 7lb cap, hoping to reduce the pressure in the system and retorqed the nuts on the head to 55lbs, topped off the radiator and took it for a spin to get it up to operating temp.
Before I yank the head off for a new head gasket, I wanted to get some thoughts on whether I'm heading down the right path. I don't know what kind of pressure the stock head gaskets will withstand before it blows them out.
Thanks.
