Tom Endy....
John S
The back door method of replacing the rear trans bearing that we talked about here: http://www.fordbarn.com/forum/showthread.php?t=42516 is going to work fine.
BTW.. I found the missing oil slinger when I pulled the torque tube back. It was installed on the back side of the bearing instead of the front.:eek:
Good thing it was because there was no spacer installed on the main shaft for the front roller bearing inside the input shaft. If it hadn't leaked I would have kept driving it and maybe torn up some nice gears. Just goes to show that when you buy a car that is unknown to you everything should be checked out before any serious driving is done. Thanks to Tom and everyone who responded to my first thread.
Now I wonder what I'll find when the engine is torn down for inspection...:(
Beware, there were two different spacers used on the front of the main shaft. The early shafts had a flat spacer that is integral to the shaft and is not removeable. The later shafts used a spacer that is rounded and has the appearance of a key ring and is removeable. The later rounded ones are usually found with the forward side that sits up against the roller bearing worn flat. I always replace them when rebuilding a transmission.
Do not install a rounded spacer on an early shaft in front of the integral spacer as you will jam the transmission.
Tom Endy
This is a late transmission with a snap ring to retain the rear bearing from moving forward. I pulled a spacer with no wear showing fron an old shaft and am about to install the works. I'll keep you posted.
