JtownJoe
Just to post a follow up on my toe in / camber post from few weeks ago: have toe in right at 1/8" or slightly under but in a very careful camber check found out the left (passenger ) wheel has 13/16 to 7/8 camber, Top leaning out, at top to bottom of 19" rim and right (drivers) side only has 1/4" camber.
I'm considering taking the axel (will have to remove it) to local heavy truck garage to see if they can correct it to near the passenger side dimension.
any thoughts on this being worth the effort & expense?
PS: I have some past experience with the garage since I have our company trucks serviced & repaired by them. Also a great source for pressing wheel studs to drums.
