racingrufus
My 1929 special coupe was making noise when you backed off accelerator when turning or not. Removed rear and took it apart, found pinion nuts backed off pinion. I am in process of rebuild.
see if you can see anything in the banjo. Also jack up the rear end off the ground,start it up, and put in in gear.Then put a foot on one of the rear spinning tires..... ,get thrown on your back quickly, then when you regain consciousness look under the car.... and see if the rear end is noisy thru the spider. Check the transmission fluid, and the differential lube for metal.
Wheel spoke?
