crazy redneck
48-52 f-1 near stock 8ba 2x2 or 4bbl is there a cam that will give some lope without killing low end torque?
I'm in flat *** Tucson. I went from the stock 4.86 gears and 34" tall tires to 3.73's and 32" tall tires so hopefully a wash there.
That "lope at idle" is bottom end torque going out the tail pipe. The more lope, the less bottom end torque.
Raising the compression ratio will get some of the bottom end torque back, lumpy cam and stock compression ratio are not a good combo for the street.
Martin.
Ross,I went with the Rochester because all the Holleys I had on it (3) leaked. I went thru 4 power valves. Since I put on the 2G, not one drop of gas has leaked. No PV issues. But it likely doesn't add anything for power.
You should be good with 3.73's and tall tires, unless you arein the northern AZ mountains?
Ross,
I'm kind of curious about your statement about the 2GC not adding power. I have an aluminum Canadian Merc 4 bolt manifold, and I had to bore it out a full 1/8" to match the small base 2GC I am going to use. It seems to me that is a significant increase over a Merc carb, much less a 94. Are you referring to an increase over a 94 or a Merc Holley? I seem to remember '94's are 150 cfm, while a 2GC is 250 cfm. I don't have any idea about a Merc Holley. (This is on a 255" Mercury with properly clearanced aluminum heads and an updated ignition.)
Denny
