Dick Deegan
That is the question.
I currenly hbave a "full flow" filter with the filter itself mounted on the valve cover and have had it installed for several years. I am currenlty adjusting valves and have the valve cover off (obviously).
My engine is stock Model A with a Snyder's 5.5 head. I use a high quality oil 10W30.
I have often wondered whether I am doing more harm than good with this filter. Oil pressures are very high when the engine is cold (15 - 20 psi) at very moderate speeds (water temperature is in the "driving range') and I wonder if I am restricting flow into the galley and thus reducing the oil at the mains and elswhere and causing excess wear on the main bearings etc. It does take about 20 minutes or so for the pressure to go down into the 2 - 3 psi range where I like to see it, indicating the the oil is finally starting to warm up.
Should I go with no filter or stay with what I have?
What do you think?
Dick
What do you think?
Dick
