Greetings, I've owned my model A for almost 9 years, and the last time I mounted two tires, I found out later that there is a mark on the tires that relates to position on the rim, or at least that is what someone told me after the fact.
So I am mounting two new Firestone tires today and the only mark I can find is a tiny piece of white tape on the edge of the rim of the rubber.
There are no paint spots that I can see to denote anything. So if this tape is a marking (and it clearly is put on both tires for some purpose) does this line up WITH the tube stem or opposite the tube stem adjacent to it? or 180 degrees to the stem?
Thanks,
JackD
Thanks,
JackD
