Tire wear
BruceUpstate NY
In 65 years of driving Model As I've never bought a full set of new tires. Can someone tell me the wear sequence: which corner wears out first and which last? I've bought a full set of used ones and want to wear them all out at the same time.
Make sure your alignment,, tire pressure is in spec, front end tight, good shocks then rotate your tires regularly
Don't know what "Tyres" are ? . . . . . oh, yeah . . . you are a 'colonial'. Probably don't have lorries or bangers either. Nor bonnets, or wind-screens.
I have tyres on my Alpine and use petrol as fuel. My A gets tires and gas...;)
rotate your tires often and they will wear evenly depending on your amount of driving if your think you drive a lot every 6 months if you dont drive much every year. if your wearing your front tires fast you are probably out of alignment.
When you rotate the tires, any specific location. Do tires need to always spin in same direction.
