Bursonaw
Recently I put a set of 600 x 16 Auburn Deluxe Radial tires by Diamondback on my 36 Ford. They look like the original tires but ride much better. Unfortunately the manufacturer does not recommend any tire pressures and the only thing they mention is that radial tires usually run at higher pressures. I’ve been running the tires at 30psi. I was wondering what others are doing if they have switched to radials?
Sent from my iPad using Tapatalk
