dan
Still muddling along with getting my car into decent shape. Next on the list is the leaky fuel shutoff valve inside the car. It's a slow leak (the handle is wet but it is evaporating fast enough that the carpet isn't wet) but annoying for the fuel smell inside the car in the mornings. And on my fingers when I turn it off or on, for that matter.
At the same time, I'm likely going to go ahead and replace the copper line that's currently between the shutoff and firewall with the correct steel line.
Questions:
1. Is it worth buying a complete new shutoff, or should I just purchase a re-build kit?
2. Any hints on what to do to prevent future leaks? Is the packing enough to keep it from leaking, or should I apply some type of additional sealant?
3. A new steel fuel line from the vendors should just fit, right? Or am I going to have to do a bit of work tweaking it? (I'm at the point where I'm considering buying a 1/4" tubing bender and steel tube, since I also need to clean up the copper-tube-to-rubber-hose mess that currently feeds my Weber)
Questions:
