fordv8j Senior Member May 18, 2025 #1 On a 59A engine, should the timing on the distributor be in the middle, or above or below the middle, to help run cool
FortyNiner Well-known member May 18, 2025 #2 I'm confused - this happens frequently. The middle of what?
KiWinUS Well-known member May 18, 2025 #3 Has your engine had a legit TDC mark and pointer added and verified correct? If not all you can do is play with it and guess. Typically a correctly setup distributor bolt it on and go. Anything more you need above stated timing make/pointer.
