The measurements above show that the initial static Model B ignition timing point of 19 crankshaft degrees BTDC plus a maximum mechanical centrifugal advance of 17 degrees equals a theoretical geometric maximum total advance of 36 crankshaft degrees. The slots in the centrifugal flyweights limit their travel and the timing advance.
Compare this to a Model A distributor which has an initial timing point at 0 crankshaft degrees TDC plus an actual manual maximum advance of 40 crankshaft degrees (via the advance lever on the steering column). The notch in the bakelite distributor body for the arm of the point breaker plate limits the travel of the plate, and thus the manual timing advance.
The Model A ignition uses a zero crankshaft degree (TDC) initial timing point so that the engine can be easily started by hand crank, however it should never be run under load in this "retarded" position. The advance lever should always be advanced 1/3 to 1/2 travel (13 to 20 crankshaft degrees BTDC) on the steering column quadrant after starting the engine, and should generally not be run more than 3/4 advanced on the column under any normal circumstances.
The Model B is a higher compression (cylinder pressure) engine which uses more initial spark advance, and lower maximum advance compared to a Model A. This is consistent with the operation of the B engine and the need to protect it from the effects of running too far retarded or over-advanced.
