DANA BIZZELL Senior Member Dec 26, 2020 #1 When timing with test light is one notch enough advance timing or should light come on at second notch. Thanks Dana
J Franklin Well-known member Dec 26, 2020 #2 Points should just begin to open when properly timed with lever in the up position.
Patrick L. Well-known member Dec 27, 2020 #3 Yep. Either is OK. Whether lever is fully up or a click or 2 down, its fine.
B Big hammer Well-known member Dec 27, 2020 #4 For standard 28-31 ford ignition, your good! That's what so great about standard 28-31 ford ignition a little more or less on the lever, adjust as you go!
