40cpe
I understand about setting timing at idle with a vacuum gauge. Is there a benefit to setting the total advance at cruise RPM by vacuum readings? If so, is it done by setting the distributor for max vacuum, or do you back off or add timing to max vacuum? I've never heard this discussed.
This is on a 5.0 engine that has been converted to a carb and points distributor with a Pertronix unit. I doubt the curve on this dist. is set up for an ideal curve for this engine.
Thanks for any insight.
