dan
All,
Keeping my daily driver 31 coupe timed seems to be a regular project and I wanted to ask a couple of questions:
1. How many miles do you go between timing adjustments? I'm putting ~400 miles a month on my car and it seems to need a timing adjustment about every 500 miles. Does that sound right? Right now I'm adjusting the ignition each time I change the oil...
2. How often should I be adjusting/replacing the points?
3. How critical is getting the timing "exactly right"? I have one of those "timing ease-ification" kits on the car (crankshaft degree indicator, distributor cam adjustment scale, etc.) but I'm not confident that I've found TDC. I'm pretty sure I can come close using the timing pin (I've checked this against piston travel) but I'm thinking that I could be a degree or two off. Will a degree or two make a big difference?
4. My main issue seems to be that when set at 0° advance, the timing seems too retarded--even with the spark level set at full advance. So I've set the timing a little advanced (4° according to the scale). I don't ever put the spark lever all the way down with the timing set like this, but it seems like it runs best this way--when I set it to 2° it still seemed to not be advanced enough at full advance on the spark lever. Assuming that I'm not running hot and not advancing the lever to full-down, this should be OK, no?
I drive in to work early in the morning (while it's still dark in the winter months). I'm not overly excited about coming to work, but the drive is certainly fun ;-)
Thanks
Dan
Thanks
Dan
