kenparker
I am in process or rebuilding a damaged engine - #1 rod babbit went bad. Before final buttoning up - putting the head back on I set the timing by using the timing pin and noticed the piston was not at Top Dead Center. Got out the trusty dial indicator, set it up and checked timing by using the dial. The timing pin and dial indicator of TDC are 8 to 10 degrees different. The timing pin has the timing set at 8 to 10 degrees before TDC.
I check several times and get same result each time. Normal????
