Looking for some clarification or insight. I know there are lots of threads started on timing but I am still having some issues.
The engine is recently rebuilt, rad flushed professionally and rebuilt distributor. New points, condenser and coil. Point gap is 0.020 and rotor to plugs is 0.025” and full retard (lever up)
I found TDC, and using the Nu-Rex wrench, I turned the wrench CLOCKWISE 2 turns til the arrow matched up to the #4 pin and tightened the rotor screw. The tail end of the rotor is on the #1 cylinder with zero (overhang?) if you get my drift. The points are open at this point. Am I wrong to think these should be just closed? As if you turn the rotor with the ignition on we should get that snap?
I have timed it with a light as well, loosened the rotor to the points just closing and getting that “snap” as well as the light on and off but just within the play of the rotor/distributor. This also leaves more “overhang” on the back side unlike the nu-Rex way, as it shows in the picture below
When I then put the button-Rex wrench on, I’m passed the #4 pin by the whole diameter.
The car is running hot (200F) and these variances are kinda throwing me for a loop. I drive mostly highway speed, spark advance 9 o’clock or so but I do find a lack of power going up hills still and I figure this is all advance/retard/timing etc.
I also had a nice gunfire style backfire after I turned the key off.
Any recommendations or advice would be great.
The attached pics are following the timing light adjustment, point gap just closed but enough to open with the play and make spark. It is also off the pin diameter using the wrench as a check.
Thanks
Gibby
Thanks
Gibby
