solsticerick
I still haven't got the car started, but I'm working on it!!
I tried to re time, but it won't start. I was told that I should double check that cylinder 1 was at top dead center; well I don't think that it was. The pin lines up with the dimple in the timing gear NEAR TDC of cylinder two. Is it possible that the gear has moved?
Should I re-time without utilizing the pin & timing gear?
Thanks!
Thanks!
