Decided I better check my timing gear after seeing what looked like teeth during an oil change. Sure enough, timing gear pretty chewed up. Lined up the gears timing marks then removed the old fiber timing gear without much difficulty. Did not move the crank. Replaced with a new fiber gear but when I align the gear timing marks, the pin holes for the new gear do not line up. When the pins are properly lined up, the index marks are off (new gear photo). I would think the pins and the index marks should all line up if I did not move the crank. Could not find an explanation in the search. What am I missing?
